try that route with a ton of coal in a ranger
What heats brakes more?
brake on, brake off. Constantly riding the pedal will cook things and cause massive brake fade. Not much else for it. You can use engine braking to reduce the demand on the brake pedal too. I also do the brake application in spurts thing on steep hills. I might be cursing myself, but I have never experienced brake fade in any vehicle I've owned, provided the brake system was fundamentally in good shape to start with. I never even managed to fade out the drum brakes in my Beetle bad enough that there was any issue stopping the car. I heavily relied on engine braking with that car though, the brakes were terrible.86 Lincoln Town Car (Galactica).
So is this what the phrase "pump the brakes" actually means? I had previously thought it meant stomping hard on the pedal and then releasing it, and repeating the cycle repeatedly in rapid succession. In many situations, I would expect that to result in basically a pair of dotted black lines down the road. More confusingly, the particular context in which I'm used to hearing that phrase is "pump the brakes to build up pressure", which I don't think makes any physical sense at all.2012 Mazda5 Touring | Finally working on the LTD again!
Depends on the context. In the snow, you want short applications and releases. On a hill, you'll want longer applications and longer releases. The speed varies but the general idea is to not hold steady on the pedal all the time.
And if you've ever bled brakes, you can pump them to build pressure when there is only a certain amount of air in the system. You'll feel it in the pedal, it will build up off the floor.86 Lincoln Town Car (Galactica).
That's funny, I always figured the thing in low-traction situations was to carefully modulate the brakes with gentle, steady pressure so they don't lock up. At least, that's what I've always done .... conventional widsom from a lot of people seems to be, "any loss of traction is always a bad thing".
I had always assumed that the repeated pumping during brake bleeding was simply to force the air out of the system, with the pump-three-times-and-hold routine primarily to apply more pressure to the trapped air.
I've noticed that if you apply the brake with the engine off and then apply it again, it's a lot harder to push, but that the pedal resistance goes back down immediately as soon as there's vacuum to the booster. But it would seem illogical that the brake booster itself is involved in allowing the fluid to return to the master cylinder ..... or is it?2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostThat's funny, I always figured the thing in low-traction situations was to carefully modulate the brakes with gentle, steady pressure so they don't lock up. At least, that's what I've always done .... conventional widsom from a lot of people seems to be, "any loss of traction is always a bad thing".
Just grease 'em up. With proper lubrication they won't get too hot. Should try running water through the motor just to be safe as wellsigpic
