Originally posted by Nathan in MI
View Post
Just got new brake stuff, whats missing?
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Hm, well, if the pedal is going all the way to the floor, then you definitely have a brake line leak as well, or at the very least air in the system, but that would usually be caused by a leak.
How's the fluid level in the reservoir look?
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Okay. Do you have the plastic reservoir, or the metal one? My guess is that the reason the fluid isn't squirting out faster is that it's pretty low already, so there's not a whole lot to leak out. You'll need to figure out how to get the reservoir open so that you can fill it back up, and then you should be able to make it leak fast enough to figure out where the leak is.
Originally posted by Nathan in MI View PostOkay. Do you have the plastic reservoir, or the metal one? My guess is that the reason the fluid isn't squirting out faster is that it's pretty low already, so there's not a whole lot to leak out. You'll need to figure out how to get the reservoir open so that you can fill it back up, and then you should be able to make it leak fast enough to figure out where the leak is.
Thanks!88 MGM 5.0 stock
the rear brake line runs up the ds of the frame
the rf brake line runs across the engine crossmember
Ah crap. No lug nut key. Didnt come with the car and there are no stores open on Sunday that can rent out the lock breaker thing.
Well I thought my housemate would have one but I also don't have a dremel to cut the brake line so I'm going to try with a jigsaw! We'll see how it goes. I'll be doing the brakes tomorrow. Thanks again guys, I'll keep ya updated.88 MGM 5.0 stock
Dremel? Jigsaw? I nearly always just use a tubing cutter ....
... though, depending on where the failure is, it's usually easier to buy enough preflared line to do the entire stretch and connect a shorter piece with a union if you need a little bit more. Also eliminates the possibility of repairing one section of hardline only to have the next section rust out a few months or a year later. Besides, compression fittings won't pass safety inspections in some states (PA for sure; not sure about HI, I just know you do have inspections there), plus doing your own double-flaring on steel = teh suck, unless you have a really nice double-flaring kit.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostDremel? Jigsaw? I nearly always just use a tubing cutter ....
... though, depending on where the failure is, it's usually easier to buy enough preflared line to do the entire stretch and connect a shorter piece with a union if you need a little bit more. Also eliminates the possibility of repairing one section of hardline only to have the next section rust out a few months or a year later. Besides, compression fittings won't pass safety inspections in some states (PA for sure; not sure about HI, I just know you do have inspections there), plus doing your own double-flaring on steel = teh suck, unless you have a really nice double-flaring kit.88 MGM 5.0 stock
Ah, well, you can definitely get away a compression union as far as functionality - I've done it before, as have others who would probably decline to be mentioned for fear of a verbal browbeating by Lincolnmania and gadget73. Not highly recommended as a long-term solution, but it can get your brakes at least functional.
Still wondering, though, how you expect to get nice cuts in your new or old tubing without a tubing cutter.I'm all but certain you can rent one for free at AutoZone if you don't have one.
I'm not quite clear about what you weren't understanding; if it helps, here's an article that talks about how to make inverted flares for your brake or fuel line: http://www.carcraft.com/howto/50919/index.htmlLast edited by 1987cp; 08-09-2009, 11:26 PM.2012 Mazda5 Touring | Finally working on the LTD again!
Well today when I went to the parts store to get a few more things she told me that its not good to to have no fluid in the reservoir. So when I got home, I went to put some fluid in and I noticed that the fluid was a different color. It did say dot approved so I put in a little anyway. Its clear yellowish. Does color matter?
After taking a close look at the whole brake line that needs replacement, it looks rather easy. The store needs the old line to get me a new one. Is it okay to just unscrew the brake line?88 MGM 5.0 stock
Clear yellowish is the normal color of brake fluid. The old stuff is probably brown, that's just from age an duse.
Re the brake line: You do kind of need to remove the old one in order to replace it ..... which line is this? 3/16" inverted flare line is what you'll normally use to replace hard lines.2012 Mazda5 Touring | Finally working on the LTD again!
I just can't get a freakin break man. I cant get the stupid lug nut keys off the stupid wheels. I got the key remover socket thing. How am I supposed to get the things off? I tried using regular size hammer and pounding it on but it barely makes a scratch. Now what, I need to buy a sledge hammer? WTF! I'm about to just return all my shit and just have a shop do it. This stupid mess is costing me ALLOT of time and money.88 MGM 5.0 stock
