brake booster
    brake booster
    will a 2004 crown vic brake booster work on my 87 cv wagon
    I believe anything up to 2002 will work, provided you also swap in the newer style master cylinder. I'm not sure if anything is different on the 03+ cars. What makes you ask?
      can get one from junk yard for 40 bucks with master on it
        Just buy a new one. Brake parts are not something you want to go cheap on. They also last a really long time. Hell, I've got the original MC and booster on my 86 yet.
            ok to use a used booster, i would not use a used master cylinder unless i had no other choice
              are 2002 down boosters smaller id like to get some room there
                93-2002 boosters are 9" diameter vs earlier 11" diameters. They make up for the smaller width with more length, however.
                  ok so thoses will fit right my 87 cv wag
                    the line routing is different, and I wouldn't be surprised if the fittings are not the same. If you don't mind making new lines from MC to prop valve, you should be able to use one.
