will a 2004 crown vic brake booster work on my 87 cv wagon
brake booster
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
I believe anything up to 2002 will work, provided you also swap in the newer style master cylinder. I'm not sure if anything is different on the 03+ cars. What makes you ask?
Just buy a new one. Brake parts are not something you want to go cheap on. They also last a really long time. Hell, I've got the original MC and booster on my 86 yet.86 Lincoln Town Car (Galactica).
ok to use a used booster, i would not use a used master cylinder unless i had no other choice
the line routing is different, and I wouldn't be surprised if the fittings are not the same. If you don't mind making new lines from MC to prop valve, you should be able to use one.86 Lincoln Town Car (Galactica).
