Steering parts.
    Steering parts.
    After completing my BBS, Im moving on to my steering. I like the Moog brand. Rockauto has everything I need for a good price. However, I cant find a parts place that carries the center/drag link. Whn they do, Its like $150.00. Whats the deal? It seems that all the parts that wear out, such as: the tie rods and idler arm, bolt up to to the center link. I feel as if the center link has no parts that wear and doesnt need changing as long as I cange all the other worn parts (they are all bad.) Is this correct? OR, do I need to just buyt a center link also. Thanks in advance.
    Vehicle: 1965 Pontiac Catalina (fastback 2+2)
    Chasis: 1982 Ford LTD Country Squire
    Drivetrain: 302 V8 carb, AOD, 8.8 with 3.08 gears.
    Big Brake swap and front suspension completed.
    the center link is a non wear item.....the pitman arm is the wear item on the panther, where the gm's the center link was the wear item
      Ok cool, So I guess I'll just clean it up and put is back.
        What he said. Center link should not go bad, so almost nobody carries a replacement.
          Can you advise what a general good backspacing amount is??? Im going to use 16 x 8 rims with 235/55/16 tires. Im using some stock aluminum lincoln wheels for now and I do like their dementions.
            What kind of Lincoln wheels? If they're off a Towncar, you're good to go. If they're from a Mark VII, you ought to have spacers to get proper clearances.
            Stock backspace for 80s 15" wheels per one of the stickies is 4.25"
              I'll load a pic in a few
                few is up
                  Here goes.
                  Sorry, got busy. I picked these rims with tires up cheap. Just to hold me over for now. However, I do like the way they fit. The car I pulled them from was wrecked and the other two were damaged. Nope, I was not able to find centercaps.
                    96 Cartier wheels. Those are the same ones yucatec has on his wagon.
                      I like how they look very much. Even these junk crapy ones cleaned up nice. I would like to get a hold of 4 nice ones with center caps. I think they look better than any of the after market rims online.
                        yeah they're a decent looking wheel. Sadly, a lot of the factory wheels look better than the aftermarkets that fit our cars. Seems we're left with the nascar looking ones, truck wheels, or really tacky bling wheels most of the time, neither of which I think look good, and both of which would look horrible on your car in particular.
                          I must say they fit really well.
