I am looking to make my axle a POSI (locked, w/e you wanna call it). I am on a limited budget so I was thinking about running a spool. Problem is, the only spool you can get for the 28 spline is a mini spool, will that work?? Also will the second link work with a stock axle, its a Ford racing trac-lock kit? I didnt know they were so cheap.
Spool
Trac-Lok
Spool
Trac-Lok
