The guide for my BBS I have been using is this one below.
Its says:
"small but important:
standard to metric brake line adapters (the newer brake hoses are a metric thread) 3/16" size I believe NEW self-locking nuts ( 5/8" - 18) for the upper control arms, unless you want to re-tigten them regularly 16" WHEELS OR LARGER are need to clear these brakes."
Im not understanding it. First off, where does the addapter go? Between the caliper and the brake line or the brake line and the frame hook up? Also, From what size to what size. He states "I believe" so Im a little worried about geting the part. I think it needs to adapt a 3/16 size to 5/8 - 18 size. Is this correct? which size should be male or female? please advise.
Its says:
