will this swaybar fit?
    I have a box 91 marquis, and I found a rear sway bar on a 1990 box linkoln towncar. It looked like a fairly skinny bar but if it will fit I will scoop it up.
    I don't believe so as that was the first updated panther for the second gens.
      only if the only mounting points are the lower control arms.....if the bar mounts to the rear axle, dont bother with it
