Hi everyone,
steering is finally done and is much better after replacement of the rug joint and pitman arm. However when I was in service, the mechanic noticed that from the left brake drum is leaking differential oil. There was also little play when he moved the rear wheel up and down. According to the mechanic, the axle shaft, bearing and seal has to be replaced - but he did not checked the axle shaft, he just saw the leaking oil and tried the play of the rear wheel. Regarding the fact that axle shaft together with the shipping is not as cheap, I would like to ask you, if it is necessary to change it, or there is posibility that just the bearing is worn out. Would you recommend to check the axle shaft first as it could be OK and just bearing could be worn out or is this check pointless and the axle shaft shall be replaced anyway? I had similar problem with leaking differential oil cca year ago and it has been solved by the replacement of the seal. Many thanks.
