What is the best posi rear end size replacement for a non posi 273 highway gear, on an 87 grand marquis 4 door gs.
rear end?????
I had that same question. Lincolnmania and Gadget advised me to look for a 83-91 8.8 rear end with the "K" code. It comes with 3.55's and limited slip. Dont quote me. Im just going from memory. There are human Encyclopedias lurching within the forum and will probably be responding shortly. You have come to the right place.Vehicle: 1965 Pontiac Catalina (fastback 2+2)
Chasis: 1982 Ford LTD Country Squire
Drivetrain: 302 V8 carb, AOD, 8.8 with 3.08 gears.
Big Brake swap and front suspension completed.
easiest to find is the K code rear out of a tow package car. If you're looking to change the gearing without swapping the whole rear assembly, you can put any set of gears in there you'd like. Traction lock units can be installed too.
A related question is what sort of driving do you do, and what are your goals for the car? Possibly the 3.55 isn't the best choice for you,86 Lincoln Town Car (Galactica).
Welcome, what part of KY you from?89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
3.55 and 3.73 are my favorites for a panther
the 3.55 you can find the whole rear.......the 3.73's you will need to install......no box came with 3.73's
You can get a Detroit Locker for a 35 spline 9". It'd be more friendly for running errands.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
