Hi everone.
I have got a question about steering gear. I have ordered remanufactured steering gear from ACDELCO and the question is, if the remanufactured steering gear has to be adjusted (with sector shaft adjusting screw). I have read here in other topics that usually there is no need to adjust it (and furtermore that it can damage the steering gear), but I believe it refered to the factory steering gear, not the changed, remanufactured one. And if it shall be adjusted, should I use the same procedure as described in shop manual, or shall i just rotated the screw half turn, try it if is ok and so on? Thank you very much and sorry for such amateur question
I have to say that I have expected bigger change in the steering (pitman arm is OK)
