Is there a big difference between a 2.73 and a 3.27? As in gas mileage and RPM.
Axle change
Just as a gee whiz I used a newer model booster on my 84 and it bolted right up to my master and works fine.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
One note about the early Mark VII MC, the large and small fittings are reversed, so you'll either need adapters, or you'll need to cut the old flares off, swap the fittings, and re-flare it. I've halfass considered doing this on my car, but I've never been motivated enough to actually do it. Maybe when my original MC gives up.86 Lincoln Town Car (Galactica).
