I have been noticing it for a while now....I can really feel every crag and crack in the road now and the cornering ability has left the building. I don't understand why when my shocks are Monroe and less than 3 years old and I have cargo coils in the rear, and 2005 mustang 17 wheels with stock 235/60/R17 tires. What component should I address first on?? any suggestions?
gradually deteriorating ride quality
Originally posted by 89LincolnTWNcar View PostI have been noticing it for a while now....I can really feel every crag and crack in the road now and the cornering ability has left the building. I don't understand why when my shocks are Monroe and less than 3 years old and I have cargo coils in the rear, and 2005 mustang 17 wheels with stock 235/60/R17 tires. What component should I address first on?? any suggestions?
Problem #2: Rear cargo coils. The Lincoln had specific coil springs in the rear, to provide a fairly soft ride. They are there for a reason.
Problem #3: Take the monroes off, and throw them as far away as you possibly can. Then, put a set of non-police KYB shocks on it, front and rear. If you don't mind a slightly firmer ride, and want some handling back, get the 'Police' spec. I never complained about the ride of the 'police' shocks, but marveled at the handling improvements....and I'm quite possibly the most picky bastard ever to set foot in GMN....short of Dean.
Possible problem #1: You might need to replace all of the suspension bushings.....
So far as what I would do first?
Lose the Monroes.
I'm going to agree with everything Larry said.
There are different grades of Monroe shocks too, there are decent ones and cheap ones that don't hold up. I'm also a fan of the KYBs, I've had a set on my Towncar for 3+ years now. I'm also back to all stock replacement Lincoln springs, primarily for the ride reasons. The cargo coils also didn't hold up well, and I had to run a lot of air in the rear air shocks to keep the car level.
I have all new poly bushings in my car too. It did firm up the ride somewhat, but the bushings have broken in and I've gotten used to it. It doesn't feel like a stock Lincoln anymore, but its far from being unpleasent in my opinion. The car also handles and drives amazingly well.86 Lincoln Town Car (Galactica).
I agree with them two. I don't like the kyb's as they aren't stiff enough for me but they are a great shocks. Your car sagging any at all? Go to each fender of your car and make it bounce as much as you can. If it bounces more than twice and ideally once your shocks are done.1989 Grand Marquis LS
Originally posted by gadget73 View PostI'm going to agree with everything Larry said.
I have all new poly bushings in my car too. It did firm up the ride somewhat, but the bushings have broken in and I've gotten used to it. It doesn't feel like a stock Lincoln anymore, but its far from being unpleasent in my opinion. The car also handles and drives amazingly well.Originally posted by gadget73There is nothing more permanent than a temporary fix.
