do panthers have the smae 8.8 rear thats in everything else? as far as the purpose of ordering gears and a posi unit?
gears- 2.73- 3.73.... acceleration gain (0-60 time)
Good luck finding aftermarket axles for a panther, folks. The mustang ones will NOT work. You will need custom length axles. Plus, that kit doesn't include them anyways.
Also, that other axle is NOT a panther axle. It's for a mustang, it won't work. Well, anything's possible with a mig welder, but it sure as hell won't bolt in...
RunUOver, there's a great shop up in PA for you to get your gears installed. PM lincolnmania (Scott), he's done loads of gearswaps for members.Last edited by Grand Marquis GT; 12-11-2008, 02:13 PM.1983 Grand Marquis 2Dr Sedan "Mercules"
As far as custom axles go, the only remotely close would be for an f series. I havent done enough measure and what not to be sure and the bolt pattern is wrong.1989 Grand Marquis LS
That first one is just gears, bearings and a limited slip. It's not a complete axle assembly and it does not come with axles.
Save time and money when you buy an Accu Axle Rebuild Kit. Take the guesswork out of buying parts to fix or upgrade your assembly. This kit replaces everything but the axleshafts! New internal parts including ring and pinion, limited-slip posi differential, and a master installation kit. This has all hardware required for complete installation including shims, bearings, races and pinion seal. Axleshafts, axleshaft bearings & axleshaft seals not included, and should be purchased separately.Builder/Owner of Badass Panther Wagons
The gear install kit is identical from a Mustang to anything else that uses the 8.8. The actual housing and the axle length is whats different. The vast majority of us do not need anything beyond what the stock axle will handle anyway. I have two brand new Dorman stock axle replacements slated to go in my car in a week or so. The pair of axles ran me $220 shipped.86 Lincoln Town Car (Galactica).
What spline is a stock panther axle, cause all the gear sets I have looked at are for 31-spline. Will that fit??-2004 Crown Victoria Police Interceptor - Daily Driver - 17" Bullitt's, 235/55/17 Goodyear Eagles, Ex-NH State Police, best 1/4 mile time; 15.3 @ 90 mph
-1987 Crown Victoria 2-Door - Project - 90k miles, Summit chambered muffler, Sunpro gauges, parked since 2010, fate tbd
the gears dont have splines........the traction lock does
