Air Suspension
    Air Suspension
    So I've been searching for like an hour and can't seem to find anything really related. So I was wondering if there is a way to move the leveler to get a little lift out of the air bags on my 98 MGM. Just for looks. I know on semi-tractors you can mess with the leveler to raise the ground clearance.
    I'll eventually have to replace them, cuz the driver side rear sags when shut off so I'd have to imagine it leaks a little. But thats later.
    1998 Mercury Grand Marquis 131k~ true duals, 2nd cat removed, H-pipe, Xcelerator Turbo mufflers, PI Manifold, 180* Tstat, K&N drop-in.
    1985 VW Vanagon 70k~
    you shouild be able to adjust the sensor on the suspension
      Yes, you should be able to do this. IIRC Zwack88 did this to his dad's LSE, but I don't know if he posted a how-to or guide. You may try PMing him.
        Hi
        There is an adjustable mount on the upper suspension arm that the height sensor sits on, just undo the securing bolt and move it but you will fuck up your springing rate.
        Regards
        Dereck
        President and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
          i thought the sensor was on the upper arm of the watts link?
            Hmmm...I'll ask zwack.
              dsi98, where in southeast wi are you? i just moved out of there recently
                I'm in Grafton. Where are you?
                  i was in walworth county, lived in elkhorn, spent more time lake geneva. then i moved to pa by way of mi
                    I see I see.
