How do i remove he steering gearbox from the steering shaft?
Gearbox removal question
Originally posted by mikeroc283 View PostHow do i remove he steering gearbox from the steering shaft?
Brute force and ignorance often works well
Undo the pinch bolt on the lower joint, drift a chisel into the gap in the joint to open it up a bit and slided the steering gear off the shaft.
Regards
DereckPresident and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
Pitman arm puller.1989 Grand Marquis LS
i think i used a 1 5/16 wrench, with a 1 1/8" wrench hooked onto it for leveragehttp://secondhandracing.com/Home.aspx
Well i got the pitman arm off. Now i cant get the box from the shaft. and the bolt in between shaft and the joint wont come out. its a 12mm and its shit now because it wouldnt come apart even after putting the socket on and trying a 11mm. is there any way i can remove it now?2018 F150 XLT 43k
1970 Buick GS 455 Stage 1 44k
1968 Buick Riviera
Many ways. Acetylene torch, plasma cutter, die grinder, sawzall.....
Get a 15mm and 18mm wrenh and take the steering shaft apart (one single nut/bolt)and get the box out of the car. It will make the removal process easier.
I would suggest spending a few bucks on some craftsman professional adjustable wrenches. They are pretty nice and have the sizes etched into the wrench. Works great for measuring nuts and bolts.Builder/Owner of Badass Panther Wagons
Originally posted by mikeroc283 View PostWell i got the pitman arm off. Now i cant get the box from the shaft. and the bolt in between shaft and the joint wont come out. its a 12mm and its shit now because it wouldnt come apart even after putting the socket on and trying a 11mm. is there any way i can remove it now?
get the slip joint slipping before you put it back together too. Those parts are supposed to move, but they've seized in the last 25 years. If it moves like it ought to, it goes together a heck of a lot easier. Usually you can soak a bunch of oil in there and drive the outer shaft off so you can wire brush the rust off the parts. If you heat it, you'll de-tension the spring that lives in there and you'll need to bend it back to keep the slop out of the two shafts where they slide together.86 Lincoln Town Car (Galactica).
