FL disc sticking
    FL disc sticking
    Hey guys, after not driving Anabelle for a while, the first few times I'll touch the brakes, the driver's side caliper REALLY grabs hard and pulls that side of the car down with it, no matter how lightly I touch the brakes. Today it got so bad, it locked up the wheel and the car sqealed to a stop from it. Is this the caliper gone bad or something else.
    try lubing the mounting pins....if it still sticks, replace the calipers and the hoses
