2005 mustang wheels installed - pics
nice!
Looks great
Are hubcentric's manditory on the rear?1990 Country Squire - under restoration
Side notes:
A. If you do the big-brake upgrade on the front, you will need hub-centric spacers on the front too.
B. Mathematically, a 1.375 spacer would be ideal on the front, in terms of duplicating the stock offset. However: 1) the center caps on these particular wheels need a minimum 1.5 spacer to fit; and 2) 1.25 spacers might not be enough to keep the inside rim lip from hitting the upper control arm.
C. Due to the slight taper on the front hubs, the wheel is just a little loose (maybe .015) on the hub. I might add some kind of shim material, but so far it's driving just fine.
Looks good!1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
If you want to copy this look, here's a hell of a deal on wheels and tires (not mine, just came across it).
