fox body sway bar, will it fit?
    has anyone tried to fit a fox body mustang front sway bar? are the dimensions close?
    dont think anyone tried, but i doubt it will work
      Not even close. Ever seen a fox body front bar?
      Only options are panther chassis bars or a custom circle track/nascar style bar.. The 98-02 Addco bar works on the boxes, it fairly close. However the stock 92-02 bars will not work because of the mounting locations. The newer stock style mounts to the spindles, not the lower control arm.
        ahhh thanks, i should have known. figured id ask since there is such a huge selection for those sway bars and not so much for ours
          Yeah, not much for the boxes at all. One of the guys here did get a fox REAR bar on his car though.
            Thread back from the dead, will a fox body REAR sway bar fit on an 86 crown vic with no problem?
            sigpic1986 crown victoria ltd 5.0
            Mods- True duals with just cats, msd cap/rotor/coil, ford racing 9mm wires,
            CAI, 180 t-stat, poly sway bar bushings/endlinks, HD shocks, cooper cobra 235/60r15, fresh paint
              My goggling turned this up... http://www.crownvic.net/ubbthreads/u...&Number=615810
                Thanks for the link jeff, it looks like it would be close because my control arms have holes on both sides...i really want a rear sway bar for cheap and the fox body ones are pretty cheap on ebay
