I have seen 2.5 tons break in mud trucks. Not really that hard to do. But most people with rockwells run ag tires and 500+ hp. Im adding the measurements of my current fender heights, top of the wheelwell so I can calculate the lift later. Front currently sits at 32" and the rear at 30 and 7/8". Ive about got the tranny and t case out of my bronco. Pics when I get it out.
4WD panther.
1989 Grand Marquis LS
Most rigs are built to dig through the mud so they can grip at the bottom of the hole. If it's not built to do that then it's not built right.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
Originally posted by Southern_Pride View PostIt actually easier to put on the car frame, and a lot safer and less ghetto. Plus you can't move the axle back on a bronco frame. Nowhere to go, frame end like 6 inches after the rear spring hangers.
Thing is the truck frame is heavier and much more sturdy- and it's designed for the mounting points of the truck suspension. A panther frame is is about as sturdy as jello behind the rear control arm mounting points and spring perches. And it ain't to study forward of that either.Builder/Owner of Badass Panther Wagons
Im adding 4 crossmembers to the frame. It should be stiff enough when done. I disagree with the truck frame being heavier. My bronco frame is about as stiff as a soft pretzel. Its bent and twists all the time.1989 Grand Marquis LS
most trucks will flex several inches between the cab and bed. id imagine that a CV would be stiffer since the body adds some rigidity. just dont open the doors with it twistedhttp://secondhandracing.com/Home.aspx
You can open them, just don't expect to be able to close it when you're flexed out on a climb.
Being boxed as it is, the Panther frame is really sturdy compared to a lot of the frames out there. People wheel on stock CJ frames all the time, despite that they're rusted to about paper thin.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
Originally posted by Freshmeat View PostYou can open them, just don't expect to be able to close it when you're flexed out on a climb.
Originally posted by Southern_Pride View PostIm adding 4 crossmembers to the frame. It should be stiff enough when done. I disagree with the truck frame being heavier. My bronco frame is about as stiff as a soft pretzel. Its bent and twists all the time.
It's twice the size and thicker....So, yeah I think it's heavier duty and stronger.
I don't see how a crossmember will help the weak point I'm thinking of.Builder/Owner of Badass Panther Wagons
A half ton frame isnt any thicker. Taller yes but not thicker. And the car frame is boxed. I could 4 link it in the rear. I got the lower control arms built already.1989 Grand Marquis LS
Originally posted by Grandmarchris View PostJust buy one of theseit bloody rocked!
wait isnt that just a lifted AWD Concord with a different name?
Originally posted by Southern_Pride View PostA half ton frame isnt any thicker. Taller yes but not thicker. And the car frame is boxed. I could 4 link it in the rear. I got the lower control arms built already.
Project cancelled for the time being. Too much stuff I didnt think about and after much measuring shit isnt gonna fit correctly. Not with out tons of modication I cant do at the moment. Back to my jack up it higher as a 2wd pipe dream for now.1989 Grand Marquis LS
Originally posted by capridrifter View PostI saw one of those with a fuel injected AMC 401it bloody rocked!
wait isnt that just a lifted AWD Concord with a different name?1998 Mercury Grand Marquis 131k~ true duals, 2nd cat removed, H-pipe, Xcelerator Turbo mufflers, PI Manifold, 180* Tstat, K&N drop-in.
1985 VW Vanagon 70k~
s_p, the 4link will be simple to do, and i would actually recommend a d44 from an isuzu rodeo, 98 or later. why? well the obvious first: its a d44. second, you get disc brakes (standard on the isuzu). only downfall....you need to convert the front to 6 lug.
go for the project mang, build it piece at a time.
