guy i had my whole front end rebuilt by this guy spring tierods balljoint pitman arm centerlink idlearm sway bar links shock guy did the whole job for 300 buck why cheaper then anyshop i asked that for sure job all together cost me about 1100 buck
frontend
300 labor? damm good price.....somebodys backyard garage?
if so his rate is probably low.......did he replace all the parts you supplied? does it work well?
1100 at a reg shop probably also includes parts with markup and labor at $65-95 an hour. It adds up real quick. Usually a shadetree guy has a much lower labor rate and if you supply your own parts, no markup there. 300 for a full front end rebuild is very cheap. I wouldn't do one for that, I've done my own and its a pain in the ass.86 Lincoln Town Car (Galactica).
