Originally posted by 1987cp
View Post
18x9.5 RIM Update
Originally posted by turbo2256b View PostThe issue with your front shocks is they might be too short. With 1000 lbs coils in the front of my car the ride height is 13 inches. My front with springs installed the car jacked up tires off the ground the distance between shock mounts was over 14". If you didnt remove the rubber bumper in the upper control arm or trim it the car might be bouncing on it. Under extream conditions undr compression the car could be riding on the control arm bumper against the frame. tHIS COULD BEND YOUR CONTROL ARM. Under extension it could attempt to over extend the shock. Which would dammage the shock. Keep an eye on the shocks for leaks.
I picked the Afco's because they were closest to half travel at the 13" distancee between the mounting points.http://secondhandracing.com/Home.aspx
