vintage Cragar rims
    vintage Cragar rims
    Would these fit a Panther?
    http://fredericton.kijiji.ca/c-cars-...QAdIdZ50441205
    '79 Continental Town Car
    '90 Crown Victoria LTD
    '94 Crown Victoria
    They have a universal bolt circle, meaning that the wheels will fit several different 5 lug patterns (they're designed to work for different manufacturers). Typically, you have to use special washers with those wheels to make them fit the given bolt circle. Turning the washers one way lets you use the larger bolt circle, while turning them another way makes them fit a smaller bolt circle. Thats how some universal patterns work, at least.
    If those wheels came off of the Camaro that they're leaning against, then one of the sizes those wheels can be used for is the GM 5X4.75. The other size could be 5X4.5, which is what you need, but it also could be something else. You'd have to measure them to know for sure. I would think that they might be a GM/ Ford (4.75/4.5) 5 lug pattern, but they could be 5X5, or something else. If you can, I'd try and get a measurement rather than taking a $300 gamble.
      yep, get a measure first but i think they will work. the cragars on my 79 are unilug like that and are in the smaller side of the slot, probably the small gm five lug (5x4.75) is the larger part of the slot.
