I got a rear sway bar for my lincoln, but I'm not exactly sure how it goes on. I have 1 hole drilled from the factory in a place where it seems like it could go but im not sure. Its on the trailing arms that go from the frame/body to the axle.
how to install rear sway bar
Nice car budd, sorry no info on the sway bar.Vehicle: 1965 Pontiac Catalina (fastback 2+2)
Chasis: 1982 Ford LTD Country Squire
Drivetrain: 302 V8 carb, AOD, 8.8 with 3.08 gears.
Big Brake swap and front suspension completed.
It's been discussed ad nausem...
You'll need to bend/cut the arms for clearance and drill 2 holes... The current hole is the front hole.
And since you aren't a noob I can say this- "SEARCH"
