For the past few days I have been hearing this awful squealing sound coming from the drivers front wheel, but when I step on the brakes it goes away and when I let off the brakes it comes back. Does my car just need new brake pads or are the wheel bearings shot?
Squeaking from drivers front.
Check both, but sounds like brake pads if I had to guess. You should re-pack the wheel bearings whenever the brakes are changed anyway so its a good excuse to check. If the pads are in good shape with plenty of material left, use some brake grease to lube up the pins, and put a bit on the back of the outer brake pad where it contacts the caliper itself, it might shut it up.86 Lincoln Town Car (Galactica).
