Originally posted by MeLikeyStripperChicks
View Post
Handling Mods
Originally posted by MeLikeyStripperChicks View PostDave, no, it's just a 2wd - wish it was 4x4, then I'd have a Dana 60 solid axle in the front... is yours a 4x4?
And a big no on the 22.5 alcoas: rubberband tires + shitty moon-crater-like roads + bigass heavy diesel engine = bad bad idea!
Ihave some E load range Brigstone EVO all terain tires 235x85x16 for sale mabe 1200 miles on them. Also 2 225x75x16s for sale same brand and make tires with about 800 miles on them. Also some half tread front steer tires 235x16 85sScars are tatoos of the fearless
Originally posted by MeLikeyStripperChicks View PostAnd a big no on the 22.5 alcoas: rubberband tires + shitty moon-crater-like roads + bigass heavy diesel engine = bad bad idea!
Don't need to go with rubber bands; use full size tires, and lift it. Not very appropriate though, seeing as its 4x2. Also, I'm not really a fan of the big wheels on a small truck either. I really don't know why I suggested that...**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
Originally posted by P72Ford View PostDon't need to go with rubber bands; use full size tires, and lift it. Not very appropriate though, seeing as its 4x2. Also, I'm not really a fan of the big wheels on a small truck either. I really don't know why I suggested that...
Hm. I stand corrected, Ivan ... apparently the cheaper steel offerings from US Wheel and Cragar aren't available off the shelf (at least from Summit) in 16x10 with a 5 on 4 1/2 bolt pattern. Guess that partly solves the problem of hardly having any 26-to-28-inch tires available to fit them. So the most straightforward 16" handling solution would be 16x8s with 255/50 or 255/55 tires. :p2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by MeLikeyStripperChicks View PostWell, it ain't no small truck - tis a regular cab dually, so just as long as any normal longbed truck, but also wider, and with the cap it looks even bigger. But if it were a 4x4 and I were lifting it I would go with some flotation tires, like 35" or 37" diameter, on some 16" wheels - more rubber means less stuck on sandLast edited by turbo2256b; 04-15-2008, 05:38 PM.Scars are tatoos of the fearless
Originally posted by MeLikeyStripperChicks View PostDave, yeah, I didn't have time to post a reply on your offer - how much for these EVOs? What about shipping? And how much you need your wheels that the tires are mounted on now (if they're steel)?Also are the 225/75s EVOs also e-rated?
My truck is 1990. I have those chrome covers on my wheels so I can't measure the actual center hole, but the diameter of the center caps are like 4.75, so likely the wheels are the same size as yours. Shipping - gas for you driving from where?Also how much for the tire + wheel, I will only need one pair as my rears are pretty decent, and tis the fronts I'd like to beef up a bit.
Originally posted by MeLikeyStripperChicks View PostMy truck is 1990. I have those chrome covers on my wheels so I can't measure the actual center hole, but the diameter of the center caps are like 4.75, so likely the wheels are the same size as yours. Shipping - gas for you driving from where?Also how much for the tire + wheel, I will only need one pair as my rears are pretty decent, and tis the fronts I'd like to beef up a bit.
Witch wheels 2 steel or chrome (would rather sell all 4 chrome ones togeather) The EVOs new were 195.00 each selling for 120.00 each for the 225x75x16s or the 285s (would rather sell the 235s as a set) The half worn 235x 85x 16s like 50.00 each.Scars are tatoos of the fearless
dont need tires that big for handling
i have a set of firestone affinity lh30's on my lincoln, 225/60/16... they stick like glue.....they have been discontinued but i'm told the replacement (firehawk gt) is better.
whatever tires you get make sure they have at least a H speed rating
