Anyone have a diagram (link) of where all the body to chassis bolts are located on a wagon?
That is all.
Thanks.
GS
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
Thanks, Mrltd! Now why didn't I think to search for "bodymounts". Didn't have much luck with "chassis" + "bolts".
GMGT, I am still toying with the idea... I would like to raise the body just enough to gain an bit more tire clearance. I have plenty in the rear, but the front rubs with my new tires if I hit a big bump.
If I do try it, I figure I'll find out what is cheaper. Hockey pucks, or some poly disks from the local rubber/plastics supply in Lexington.
Might be a good opportunity to por15/herculine the floor, and add a few more body mount locations to make the car even more rigid. (old demo derby trick)
Too bad 4x4 would be such a pain to install...
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
will those fit a 93??
i dont know much about the suspesion bushings. i just noticed yesterday, when i was replacing my starter, that almost half of the front bushing under the battery was gone.
thanks
-ryan
yeah, i didnt want to mod it. thats ok though. i noticed that the front control arm bushings are quickly becoming poo. figured i change the bushings and struts at the same time; kinda like a front end make over. but the rear will follow soon.
-ryan
