4 Corner Scale results for the SVT Vic.
    I hot a hold of some Longacre car scales. So the results are as follows:
    No driver,
    Battery relocated to the trunk,
    3/8 tank of gas,
    17X9 aluminum wheels with 275/40 Sumit. HRT-Z tires,
    NO SPARE,
    NO BUMPER JACK,
    With trailer hitch,
    Total weight: 3758 lbs
    994 LF RF 1053
    877 LR RR 834
    Cross %: 51.4 %
    Left %: 49.89 %
    Front %: 54.5 %
    Rear %: 45.5 %
    WITH ME IN IT
    Total weight: 3923 lbs
    1064 LF RF 1066
    932 LR RR 861
    Cross %: 51.9 %
    Left %: 51.9 %
    Front %: 54.3 %
    Rear %: 45.7 %
    noice, pretty much a ballanced and symetric car!
      your car is still full weight right
        Where you able to fine tune the results? I know I have always wanted a set of those scales but alas....I cant afford it
          Well, they aren't mine, just barowed. Can't tune them without coi -overs or adding wedge and what not.
          My car is essentially full weight.
            hmm...would moving some parts around a bit help at all?
              is your battery in the engine bay? if so you could move 40#s from the left front to the right rear
                his batt is in the trunk... says in the post...
                You could adjust the wieght with spring spacers....That's pretty good for a near stock car.
                  I assume those weights are pretty good? It'd be cool of several members in the same area could chip in on a set of scales.
                    I just go up the road to the lumber yard to weigh a car.
                    My '79 Continental Town Car weighed 4950lbs empty...
                    '95 Ford Bronco XL -
                    sigpic :rebel:
                      Total weight tells you nothing about weight distribution.
                      The set of scales I used would cost about $2500 so it would take quite a few contributors.
