Questions?
    Questions?
    Hey guys...
    What size is the rear brake line on an 89 box, the one that runs down the drivers side to the rear axle I heard it has to be double flared??? I guess when I replace it I will run it from the proportion valve to the rear "T" fitting on the axle.What size are the brake line nuts.Are they metric or standard size nuts. Also I have to refill my rear end I dont have an owners manual so I cant find the info on how much diff fluid to use so I bought 3 quarts Do I use all 3 it seams to be close to the amount that came out of the diff in the first place. I bought Castrol hypoy C gear oil good for conventional and limited slip diffs and its 80w-90 sae. (dealership is closed today so I couldnt call them for info)and yes I did a search.
    Thanx PORKCHOP
    Brake line should be 3/16", and you just fill the rear end until it starts running out the hole. 3 quarts should be a great plenty.
      3/16", Standard, should be fine, fill to the inspecion plug hole. Like Nate said..
