PIcked up a K code rear, want to add discs
    Group
    i picked up a "k" code 3.55 rear today, and would like to swap on the 92-up rear discs, I have done the rear disc swaps on fox mustangs, and wonder if its the same for the panthers, I need the calipers, rotors, caliper brackets etc..What about axles? DO i need the disc axles or can i use the drum axles?
    joe
    you need to keep the drum brake axles. Later models have a wider housing, and use a longer axle. You can't use a 92+ axle in an older rear, it'll stick out too far.
