Proportioning valve problems.
    The proportioning valve on my 1985 Grand Marquis blew out last Friday and I can't seem to find one anywhere. None of the local parts stores can find one that isn't universal fit and the junkyards around here have crushed everything pre-1990. Is there anywhere I can find a stock replacement part? Not that I need brakes anyways, what with my steel bumpers and plenty on trees/rocks/pedestrians around...
    Go to French Lake just west of Annandale, they've got some boxes...can't guarantee the usability of a part like that, but they'll certainly have 'em.
    For all of your auto part needs, contact French Lake Auto Parts, Inc. in Annandale, MN, today! Call us at 320-274-8497
      teamfordparts.com has them, $157 for a sedan prop valve, $93 for a wagon.
      Now I'm curious what the hell the difference is lol
        Perhaps they proportioned the braking effort differently on wagons because the weight distribution is slightly different? *shrug*
          that would be my assumption as well, but I'm curious what the split is.
            The cheap way out would be one of those adjustable brake bias valves from Wilwood, had one in the Chevy but I needed it anyways cause the different tires front/back and the hydroboost setup. Tis like $30 or so, and allows you to dial yer rear brakes pressure to where you want it. Downside is that if you blow something (hose, caliper, wheel cylinder, steel line, whatever) this valve will not seal off that part of the brake circuit, unlike a stock prop valve that will (or at least is supposed to).
              You could use an aftermarket prop. valve. Wilwood makes them, and I believe they're like $60. I believe Michael (1987cp) used one on his car. You may want to PM him if he doesn't post here. Its adjustable, so you can proportion the brakes how you want them.
                90-91 boxes use the exact same brakes....The proportioning valve should be the same...
                Wagons have more wieght, and come with the 11" drums. so, I'd expect them to be different.
                  yea but your big brakes/rear discs work well right? if it were me i'd go for the cheaper one
                    well amazingly enough its in the book, and they are not directly interchangeable. The fittings are different sized.
                    on the primary side, the wagon has 7/16" in, 3/8" out. Secondary side is 1/2" in, 7/16" out
                    on the sedan, primary in is 3/8", primary out 3/8", secondary in 7/16" out 7/16"
                    wagon proportioning split/slope 300/.43
                    sedan proportioning split/slope 300/.36
                      +1 As you've probably read, Nate, my experience was likewise that a stock replacement prop valve simply couldn't be found. They're horrid to get to anyway, so I wasn't sad to be rid of it. In a pinch, you can run without a proportioning valve if the problem is like mine was, since too much pressure to the rear brakes feels quite a bit safer than having no rear brakes at all!
                      Check eBay ... adjustable valve I put on the LTD was from Stainless Steel Brakes and was left over from a kit, never installed, and I got it for more like $25 (the Mercury has a Wilwood bought new from Summit for $40). Saw others, including Mopar Performance brand, with bids as low as $15.
                        I think I'd have to agree with the aftermarket solution just for price reasons. That stock valve is in a rather nasty spot. I've cleaned mine and had a hard time getting at it. I wouldn't want to replace it.
                          looks to be accessible from fenderwell area easier than from above.
                          Addicted to 86-87 Panthers
                            If you have skiny hands you can easily reach the thing from above, but once stuck line nut and you're about done, it can be reached from below too, but if you still got stock downpipes it can be a bit of a challenge.
                              Success!
                              Fortunately, I live close to the world's oldest Ford dealership, and they happened to track a NOS one down. Apparently they rarely go bad so hardly anyone ever orders them. My Dad (who splits the cost of the car with me since we both drive it regularly) nixed the aftermarket prop valve since there's no fail safe. Since it was only 18 degrees today we had our buddy with a heated shed install it since he owes my Dad for selling him a Celebrity that was a piece of junk. It was a good thing too since he noticed the water pump is leaking like mad.
