Wagon Cargo Coils
    Wagon Cargo Coils
    Alright, I will be going to my parts guy on my way home from school tomorrow to buy some rear springs and shocks.
    I already know about the F150 shocks and all, but I'm a little concerned about the springs.
    I would like to go with the wagon CC 819's, but I don't want it to be too raised up in the back. Right now it sits a little low in the back (sometimes it sits lower on the drivers side than the passengers side). But, when I put my summer wheels on the back (w/ 275 60 15's) they rub on the outside fender lip when I have rear passengers. The front end sits a little low on my car ('90 P72), so any extreme lift in the rear would make it look really goofy.
    I want to know this: will the CC 819's make it look retardedly high in the back? Or will it look okay once I mount those 28" tall 275's?
    Also, I'd rather not use the CC 817's as their spring rate is lower (165 lb/in) than my stock cop springs (175 lb/in), or so I believe.
    It will be pretty high... Look at Natehawks car. Regular wagon springs might be a better choice. I would also wait on the shocks, unless you know for sure that the current ones are at full extension.
      The straight rate will still provide some lift though, correct?
      The spring rate is also higher than what I have now (182 vs 175; on tired cop springs). Hmmmm...
        The wagon springs will give you lift, either way prog or variable. they are a taller higher rate spring.
        Gabe is running stock wagon springs on his car...So are a few others. Even the seda ncargo coils would help, and using poly isolators would give you a bit more hieght if needed.
          I put the wagon Variable Rate coils on the back of my tudor and it raised it to a retarded degree. My 225/70/15s look like skateboard wheels. If you just want to lose that "sway-back Granny" look, I would recommend the Variable Rate Sedan coils. They gave my ex's 91 a nice lift, bout half what I got from the waggin ones on mine. I should have some pics to upload tomorrow or saturday of the tudor with the tall springs... Driving like this makes me feel like my name should be Cletus and the deed to my house should have "Double-Wide" on it somewhere.
          Good Luck
          The Admiral
            I have original 1985 wagon coils on my car in the back, and its pretty close to level front > back with the new front coils. It would probably be slightly higher with new regular wagon springs, but not as high as the wagon cargo coils.
              I've found that the CC817 Rear Sedan Cargo Coil and 8650 Front Wagon coil to be a good combo. Running it on both the '88 and '90. Gives the car a little rake with a big plus in the handling department. Those CC817's hold up nicely with the trunk loaded, too.
                Ive used both the sedan and waggin cargo coils... the rear waggin cargos in the 85 did make it almost silly high, but they did settle a bit and it looks just right now, just alittle rake. I should mention though she sits a little high in the front so the rake might still be more extreme if the front springs are droppy a bit. It seems to me like most towncar and mercs seen to sit lower in the front than vics...
                I put rear sedan cargo coils in the 91, and they boosted the formerly slightly saggy rear up about an inch, making it sit pretty level. The front of the 91 is nice and high though too.
                Id use the sedan cargo's, police spec if they are availiable, they should level you out without the rake look.
                  Another thingto take into consideration is the amount of crap people normally lug around in their trunk. Like subwoofers....
                    Well, I didn't go to the parts store today because its shitty here today. I'm not going to go with the cc 819's though.
                    The cc 817's have a lower spring rate than my straight rate stock cop springs though. I suppose because they are vari- rate that they should be a little better though, right?
                    Is there a police spec cc?
                      I have the CC819's in and it looked too high at first. I know I had to adj. the headlights and that I can carry 4 truck battery's, a case of oil, and some tools in the trunk with ease. It also rides a little stiff, but, it doesn't lean in the curves. If I had to replace them again I would use CC817's. I need to do the front springs first.
                        weight. Also, Towncars have different springs, specifically because they weigh more. I've run Vic HD springs in my Lincoln before, it sits almost 2" too low with them.
                          I found some pic of before and after. The ones in the snow dated 2005 are the before.
                            Glen, your fronts are fine and just where you want them to be as far as ride height goes. Also, that's one very nice car you got, love the stance too, but then again I'm a bit partial to raked Panthers:
                              Glen, that first pic is with wagon cargo coils? That doesn't look bad at all to me.
