Does anyone have any ideas on putting a 9 inch in a Panther? I thought about getting one that is meant for a Fox body or pulling the one from my dads 65 Galaxie but I'm not sure if the control arms would be in the same spot.
9 Inch
I was just mentioning in the convertible thread that I noticed under a '77 or '78 Marquis that it had a 9" with a four-link. No guarantee the mounts are in the same place, but it might be worth looking into. Of course, your Galaxie mounts may well be very similar to the ones I saw under that Marquis.
Or you could just buy any 9" in an appropriate width, preferably with a nodular case, and weld on Panther mounting brackets.2012 Mazda5 Touring | Finally working on the LTD again!
my 77 ltd had some weird rear definitely wasnt a 9"
got any 72-79 torino based cars in the junkyard you work at? they had 9" rears and rear coil springs, and just about the same size as a panther
Originally posted by lincolnmania View Postmy 77 ltd had some weird rear definitely wasnt a 9"2012 Mazda5 Touring | Finally working on the LTD again!
All I really know about the 8" is that it's a removable-carrier design and looks sort of like the 9" externally. It was used on base-model first-gen Mustangs though at least '68, and I think two-barrel small-block models as well. No idea what else they went into.2012 Mazda5 Touring | Finally working on the LTD again!
the 8" looks just like the 9"......just the housing is a little smaller......my 77 ltd's rear had a cover on it........8" and 9" rears do not have a cover
All the mounting points are wrong. You will have to make all new mounts for the axle.
Lotta work for something that isn't really needed.... I have yet to blow an 8.8 apart...And everyone knows how I am with abuse...Builder/Owner of Badass Panther Wagons
Originally posted by lincolnmania View Postthe 8" looks just like the 9"......just the housing is a little smaller......my 77 ltd's rear had a cover on it........8" and 9" rears do not have a cover2012 Mazda5 Touring | Finally working on the LTD again!
