hmm, DUH.... Check your tire pressure
    Was having some drivabilty problems with the wagon, surprisingly the tires were all about 8 psi low from the temp drop....
    Go pump up your tires!
    I keep a tire gauge in each car
      I usually do.. Took mine out to check the other car. Knew they were low, but couldn't pump em up at home due to the compressor being frozen....
        oops
          Just got my car running for the first time since Wedsday. Had a couple major temperature changes since then. Took it out for a drive and its all over the road, all the tires are low, so I gotta drag the compressor outside tommorow. Yay!
            one of mine goes low every few days. Not sure where the leak is. Think I'm gonna cheat and slime it. I can tell when its low because it pulls and drives all funny.
              Don't... we sell that stuff at my store and I've heard bad things about it. Apparently it works great until the time comes to take the tire off that wheel. From what I've heard it sticks to the wheel and just makes a big mess. Just have a tire shop find and fix the leak so you don't have to deal with it.
                Well that's what wire wheels are made for - if you use the right one and you're careful with it all will be good.
                  My dad worked at Goodyear for a bit after retiring and he said some of the shops wouldn't work on a tire that someone used slime on. Are your tires dry rotted any? Could be the valve stems or a bead leak aside from the usual nail in the tire. I had new tires leak on me once when the place skimped on bead seal, not going there anymore.
                  1986 Grand Marquis LS 2 Door
                    has it always done it?
                    my guess is the valve stems i have the same problem on one tire.. i cheaped out and didnt get valve stems cuz i figured none of them leaked before but after i got the tires put on 1 leaked. isnt it damned annoying having to fill up one tire with a few pounds every week? lol
                      My Lincoln will start pulling a little, and I'll check the tires, and one of them will be like 15 lbs low. I hate those tires (or valve stems, whatever, I hate the situation.)
                      Back in the saddle again!
                      2004 Crown Victoria Police Interceptor in Unimaginative Bureaucratic Brown
                      Bone stock... for now.
                        No, its only started doing this over the last month. Tires aren't dry rotted, they're about 2 years old and in pretty good shape. New valve stems were installed with the tires, as the rims didn't have any valve stems in them when I got them. I tried looking for bubbles after getting the tire good and wet in a bucket, but I didn't find anything. Its a slow enough leak that its hard to pinpoint. Probably something stupid, its just irritating. My truck leaks on the same wheel too at a bit slower of a rate. I dunno wtf the deal is.
                          With all that you said, I'd say the best guess is the bead/rim seal is probably leaking a little bit. I had new tires put on newer almost new rims with no corrosion and they had to be remounted to stop a leak like that. I know it's annoying, but if you had a place mount them maybe they'll remount it for ya?
                            I had a set of tires mounted on the S-10 a couple years back, and one started leaking about two days later. Took it back in and it was leaking around the bead, so they broke it down and remounted it, and it still leaked...they wound up putting some kind of black, tar like substance on it, and it never leaked again.
                            People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf. ~ George Orwell
                            1990 Crown Vic, 2006 Ford Fusion, 2003 Ranger
                              thats what i was figuring as well. I can get my uncle to re-mount them if thats the problem. I got these at Firestone in Reading, which is about an hour and a half from me. Not interested in driving up there to get re-done, I'm sure they'd charge me a bunch. My uncle is 15 minutes away and he'd probably do it for pretty cheap for me.
