Originally posted by torquelover
View Post
Looking for these parts, please help!!!!
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
You wouldn't necessarily need it just because you swapped to a T5, but it wouldn't hurt, regardless.
I have a link for the cross drilled rotors. I'm at school now in the computations lab though, ands its on my home computer. If I remember I'll add it when I get home.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
Originally posted by torquelover View PostI've had good luck with the Performance Friction pads with wide, sticky tires and tightly adjusted rear 11" drums (all stock on my Vic). Bleeding the brakes thoroughly really helps pedal feel/firmness and allows you to threshold brake much easier. While I agree you can never have too much in the braking department, this setup is pretty good. Enough for my Vic's power levels, anyway. Want more? Look up switching over to the later style larger rotor/spindle/caliper assembly. Beware the higher ratio rears if you like to drive at high speeds on the highway; a new driveshaft might be needed.86 Lincoln Town Car (Galactica).
If you get higher level performance pads you will think twice about upgrading your brakes. The pads I go to the track with will brake harder, faster than any big brake setup with street pads. I can lock up 275 HTZ tires at 90mph without even trying. I have no problem dealing with 120mph braking zones with Hoosier slicks. However, bigger brakes do one thing, they last longer. With the right pads, you can make any brake setup perform as good as you want, but with bigger brakes you can make it do that for longer.
I have run Performance Friction Z-Rated, and Hawk HP-Plus pads on my Vic with great success on the track. The Z-Rated pads do not squeak on the street so they are better for daily driver cars. The HP-Plus (NOT HPS) squeak all the time, so they can get annoying on the street, but they brake even better. Both of those pads are just entry level track pads.
