Im looking for front cross drilled or slotted rotors, where can I get them? Also I want to upgrade to a 3:73 rear end, Where can I get the gears brand new? Also I want to overhaul the complete rear end What parts/bearings will I need? Thanks so much guys!!!!
Looking for these parts, please help!!!!
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
What year is your car?
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
There aren't any cross drilled brake rotors for your car; at least not that I know of. As for the gears, you should be able to get those direct from Ford, or from Jegs or Summit. For the rear rebuild, you'll want a ring and pinion installation kit. You can get those for between 70 and 110 bucks or so on eBay, depending on how complete a kit you get.
Haha... LMAO. Sorry, not any ricer parts available.
The rear axle is a FORD 8.8. Buy parts for that. Available anywhere. Including the gear install kit. THen maybe axle bearings and seals. Are you planning on installing weverything yourself? Properly installing gears requires a few specialized and kinda expensive tools.Builder/Owner of Badass Panther Wagons
for new gears use ford racing gears......best price i've found is on www.gefracing.com
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Air tools are nice to have for getting the pinion nut loose, also need a torque wrench for torqueing the main caps and pinion nut, inch/pound bending bar type (not a clicker) torque wrench for checking pinion bearing preload and carrier preload, dial indicator for checking backlash, bearing race installer, slide hammer for removing old wheel bearings. It can be done (I did it on mine), but it's not for the faint of heart, and not for the beginner mechanic (not saying you are; I really don't know).
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Weeelllll, I hate to burst the non-rice bubble but cross-drilled rotors do exist for these cars. I have seen a set with my own eyes. They are, however, basically worthless and won't actually do much useful for you as far as stopping power. If you want more stopping ability and don't want to upgrade the brakes, about the best you can do is police calipers and a high quality brake pad with all new brake parts up front.
If you're doing the rear, I'd suggest rear disc, or at an absolute minimum, 11" rear drums as an upgrade back there.86 Lincoln Town Car (Galactica).
supposedly powerstop makes a cross drilled rotor
http://www.amazon.com/gp/product/com...ef=au_pf_fb_cc
and so does SP Performance
http://www.rotorsandpads.com/F54-38-...x?count=0&of=2
but like gadget said, they aren't going to help that much, plus why go with the added expense. Just get a good quality disc (less tendancy to warp), not some cheap chinese junk, and a good set of pads, like Hawk or Performance Friction.1987 Country Squire LX Wagon 5.0L: Daily Ride......1964 Lincoln Continental 430ci: Toy #1.
Originally posted by gadget73 View PostWeeelllll, I hate to burst the non-rice bubble but cross-drilled rotors do exist for these cars. I have seen a set with my own eyes. They are, however, basically worthless and won't actually do much useful for you as far as stopping power. If you want more stopping ability and don't want to upgrade the brakes, about the best you can do is police calipers and a high quality brake pad with all new brake parts up front.
If you're doing the rear, I'd suggest rear disc, or at an absolute minimum, 11" rear drums as an upgrade back there.Last edited by torquelover; 11-13-2007, 09:58 AM.
