Give it a week or two, they will settle some. Also, figure you're probably closer to stock height now, your old springs were probably fairly tired. The HD coils on a CV do raise it a little. CFI cars are also a couple hundred pounds lighter on average than a SEFI car.
gears and springs
I thought it might raise it a little... but it did more than I thought. I removed the A/C and smog pump a few weeks before, so that took even more weight off the front... the gap is HUGE. And gross.
I'm picking up a set of those spring shortening clamps tomorrow when I pick the car up, gonna put them on the front for a while so she doesn't look so bad. Atleast until me and the guy at the shop can figure something out. Still had to pay for labor though. $200. Will take pics tomorrow if I get the chance.
Oh, and one of my stock front springs was starting to collapse.Last edited by murphmobile2; 10-16-2007, 01:11 AM.1984 Ford Crown Vic LTD, The Murphmobile (RIP)
lowered cars with stock rate springs are not a good thing though. Just ask my wheel well trim about it. HD front coils on a Townie put it about an inch low in the front. The right side trim is beat to crap now from the tire hitting it on right turns whenever I have someone in the car.86 Lincoln Town Car (Galactica).
Went out and took some shots today, and yes the springs are green, I felt like being different lol.
It may just be the way the car's sitting, as my driveway is REALLY crappy, but I think the front end is leveling out a little. I'm going to leave her like this for a while and see what happens... fortunately it does handle better though. One of the old front coils had compressed itself on the base about an inch, so atleast I know why it sagged on the drivers side now.
Wish I would've taken a picture of the old ones side by side lol.1984 Ford Crown Vic LTD, The Murphmobile (RIP)
it will settle more mang
hey if you need help with gear install, you could always take a road trip to my shop
Originally posted by gadget73 View Postlowered cars with stock rate springs are not a good thing though. Just ask my wheel well trim about it. HD front coils on a Townie put it about an inch low in the front. The right side trim is beat to crap now from the tire hitting it on right turns whenever I have someone in the car.
Originally posted by MeLikeyStripperChicks View PostYeah, but yer car is a freak of nature - i have larger tires than you do, and I'm riding lower than you, and I still get a light rub only when turning at full lock and hitting a pothole or a ditch or something of that sort. But, based on that pic, half a coil per side needs to come off, car will go down with about 1" which should be just fine and still safely allow for some sag when loaded.Builder/Owner of Badass Panther Wagons
Originally posted by murphmobile2 View Postbut it RAISED my car. Raised it A LOT. There's about a 2" gap between my front wheels and fender, and the rear looks like I put my air shocks back on.
1987 Country Squire LX Wagon 5.0L: Daily Ride......1964 Lincoln Continental 430ci: Toy #1.
1984 F-250 4x4 4.9L: Toy #2.............................1968 Volkswagen Bug 2.0L: Toy #3.
1989 F-250 4x4 5.8L: Emergency backup and work truck...
Originally posted by mrltd View PostHave you replaced any ball joints or bushings? If not, the added slop will allow a lot more clearance.
