Pulled the rear apart today. Left axle is marred on the bearing surface. Both the axle and bearing will have to be replaced. I also found the right axle was leaking also, but not nearly as bad. Sucks because the parking brake shoes got drenched in fluid and they are not cheap- 50 bucks for them. New bearings, seals, and an axle.
Also removed the traction lock to assess the condition and decide what to do with it. Clutches look good, little beat on the tabs, but the friction material looks good, going to reshim it and reinstall.
