Yesterday I was changing my oil and spending some time under the front of my car. I was greasing fittings and such when I notcied I have a problem. I can see daylight around the sway bar bushings. They are clapped out. I need to replace them, and I'd like to change the end links at the same time. What should I use? Should I buy factory pieces, or something else (urethane, etc)? Do they make those prothane things for my car (1990 P72)?
If you have part numbers, or specs, that'd be great. I haven't yet done much research on this. I need endlinks and bushings though.
Also, I should probably change my front brake pads, as I have a feeling they are what is making the mystery squealing. It goes away when I hit the brakes, and I haven't changed them in a spell. The rotors and all look good. Whats the best brand of pads I can buy for my factory stock braking set up?
Thanks in advance for all input.
