pony wheels update
    pony wheels update
    I got the pony wheels on the Lincoln today with the 1.25" spacers and they look good and make the handling a lot better. I'm just wondering about the integrity of the spacers and how well they stand up to highway speeds and heavy cornering. Do I have to re-torque them? They cost 112.80 shipped for all 4, is that cheap??
    I would retorque them after 20 miles or so.
    As for integrity, I've autocrossed on mine for 2 years and beat the living crap out of it. Not one issue. About 20K on mine.
      Yeah, retorque them a couple times. After the first retorque abuse the hell out of em and make sure they are maintaining their torque. Other than that MRLTD is standing proof they are fine....I personaly just can't deal with it as a concept. Something about it just doesn't sit right with me so I won't use them.
        I felt the same way... But They have been working, and they use them in quite a few motorsports. So, I deal. If I could afford it I would get some wheels with correct backspacing.
          i've been to florida twice and georgia twice on the spacers. no issues........about 25,000 miles
            Mine have been on since early 2006, no issues. I torqued the spacer to the hub to 100 ft/lb with a torque wrench, and did the wheels the same. Just make sure you don't over-tighten them, or tighten them unevenly and you're fine.
              I did the same... 100 onthe spacers. 90 on the wheels though.
