Originally posted by Forcus
View Post
Another "will these fit" thread.
Originally posted by Pirate View PostIt's not too difficult to add, provided either you or someone you know can weld. The one thing to keep in mind about panhard rods: The frame attaching point should only be maybe 2-3 inches higher than the rearend mount at normal ride height, which is also dependent on the length of the bar....If you weld it in at a steep angle, the car will actually lurch left or right on almost any bump, so you do have to be a little careful there.http://secondhandracing.com/Home.aspx
unfortunatly i dont have any pics of the panhard set up we built.
this is a maximum motorsports panhard bar set up for a fox mustang, you can see how they lowered the bar to be near even with the rear axle.
Originally posted by mrltd View PostWith the stock gastank, it's gonna be tough to put a panhard in. I've looked at it many times.http://secondhandracing.com/Home.aspx
