I'm getting some pony wheel's for Anabelle and I need to know how thick to get the spacers. Ebay has them in 1.5, 2, 2.5 etc.
Wheel spacer size?
Wheel spacer size?
1" or 1.25" would be good.86 Lincoln Town Car (Galactica).
Originally posted by mrltd View Post1.25-1.5" if you are running stock brakes. 1" is fine if you are running 98-02"
Overkill had them on his towncar and he had the centercaps on the front.
Originally posted by mrltd View Postyou won't be able to run centercaps on the front wheels
those are different style centercaps than the bullits or the hhp's
jim the bullit wheels will fit, you need a 1" spacer. using said spacer the caps should go on
i am using 1" spacers with lsc turbines and big brakes......i had to grind my calipers for the lsc wheels to fit.....they are really thick........17" mustang wheels 94-04 1" spacers, no problem.......05 to present stang wheels you need 1.5" spacers
oh and get billet aluminum spacers......my first set was these pos cast transdapt spacers.....i had a wheel fall of on my way to georgia.....lucky i had just left the house, and it happened next to an auto parts store......dont be cheap about the spacers.......the ebay ones are decent, around 100 bucks for four mang
