I'm looking for the newer 16" Pi steelies with center caps. Anyone know where I can find them? I'd prefer them used since I'm on a TIGHT TIGHT budget. Also what size tires do newer PI's run? what's the width on the steelies 7" ? I'm thinking 235/60/16's all around on the '88 what do you guys think? any suggestions on steel wheels similiar to the PI's? Older dodge rallies?
Wheels
Hmm, marketplace, WTB section. Ebay, etc....
Just so you know, all the 16 steelies on all the cars, including the civilian cars are all the same. Yes ,they are 7" wide. 235's will be fine. Stock is 225/60Builder/Owner of Badass Panther Wagons
06+ cars have 17" wheels.
I say the Dodge rallies if you're looking for a nice steel wheel. Not sure of your budget, but they can be bought new from Coker tire.
These wheels don't rub and they look very nice. Most are 7" wide, but Coker sells different sizes. My brother has them on his car. I've seen them at swap meets (4 unbent for $75).**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
the 03+ wheels require a 1.5" wheel spacer.......same goes with 05+ mustang wheels. and i do believe these new weird fords lincolns and mercurys some of them are 5x4.5
Originally posted by P72Ford View PostI thought 03- 05 cars with the 16" steelies had a different offset. They are the goofy looking "flat faced" wheels. I'm pretty sure they have a diff offset than 98-02 cars. The 03-05 wheels had problems too. I know the 04 I have had the wheels replaced. The problematic wheels had fewer perimeter holes I think. My 04 has alot of perimeter holes, and there was paperwork for the recall on the wheels.
And from what I've noticed, the dodge fullsize (charger/magnum) also use a similar wheel. Heck the SAP and magnum wheels look identical.Builder/Owner of Badass Panther Wagons
Originally posted by FastGallopingPonies View PostI'm looking for the newer 16" Pi steelies with center caps. Anyone know where I can find them? I'd prefer them used since I'm on a TIGHT TIGHT budget. Also what size tires do newer PI's run? what's the width on the steelies 7" ? I'm thinking 235/60/16's all around on the '88 what do you guys think? any suggestions on steel wheels similiar to the PI's? Older dodge rallies?
torquelover has 235/60 Kumho ASX's on his car, and they do fill up the wheelwells a bit more than my original-spec 225/60s.2012 Mazda5 Touring | Finally working on the LTD again!
