I was poking around my car today looking at the tire on the passenger side where it hits the fender, and I noticed its pushed outward relative to the fender a lot more than the driver's side. I got out the tape measure, and sure enough, the body is actually pushed towards the driver's side by almost 3/4 of an inch up front in front of the radiator support. Its over by about 1/4" in the back behind the rear tires. The body mounts are dead, but they aren't visibly skewed nearly enough to explain almost 3/4". The car has never been hit as far as I know. All sheetmetal is original, and the frame has no structural damage. Could the frame be tweaked that far out of square that it would actually be off center from the body without the body mounts being massively distorted? How the heck do I fix this?
its crooked, wtf?
its crooked, wtf?
I drive a Lincoln. I can't be bothered to shift like the peasants and rabble rousersTags: None
tried that, it doesn't move back unfortunately. Its kind of annoying, I pretty much can't have passengers in the car because even an average sized person is enough to make the tire start catching on the fender on right turns. The wheel well trim is all screwed up now, and the fender lip is bent out of shape. I wonder if I can get a come-along in there behind the header panel and hook it to a sturdy spot on the rad support and to the frame on the opposite side and pull the body back the other way. Hmmmmm.86 Lincoln Town Car (Galactica).
Originally posted by Blaze86Vic View Postgo over to the driver side fender right behind the header panel. Shove your hip into it. Problem fixed. LOL
My front end moves around more than that when I lean over to work in the engine bay. Though the body mounts may not show it, there is room for it to slide on them and it does.
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Hey, hey, hey, kids...keep in in teh battlefield.
Yeah, sounds like bodymounts. There is a HUGE gap between the rubber mount and the ID of the frame mount. There is about 1/2" of open space, so 3/4" can easily be had.Builder/Owner of Badass Panther Wagons
Originally posted by 86VickyLX View PostI mean the procedure.86 Lincoln Town Car (Galactica).
Originally posted by mrltd View PostYeah, sounds like bodymounts. There is a HUGE gap between the rubber mount and the ID of the frame mount. There is about 1/2" of open space, so 3/4" can easily be had.86 Lincoln Town Car (Galactica).
