I was looking at some 18x9.5 rims for my 89 Mercury. They have 4.5” of backspacing. I was thinking of using a 255/45/18 or a 285/40/18 tire. Would the 285/40/18 rub in the front? Or would it be ok?
Tire Size for 18x9.5 Rims?
285/40 is a big tire, i doubt it will fit up front.http://secondhandracing.com/Home.aspx
the 285s should fit in the back, im running a 325/5015 on the rear of mine, thats 13.5" section width and 28" tall, with 5" of BS they would fit just fine. Not sure about the fronts thoughhttp://secondhandracing.com/Home.aspx
Originally posted by mrltd View PostGood god those are expensive tires....I fit 275/40/17's on the front of mine without any issues. Not as wide rims on my car though.
Mrltd, what is the backspacing on your rims?
I was going to put 255/45/18 on all 4 rims, those would have cost around $500 for all 4 cheapo tires. But while looking at 18x9.5 rims I noticed that the new mustang GT500 uses 18x9.5 rims. The GT500 uses the 255/45/18 in front with the 285/40/18 out back. So now I’m thinking about 285/40/18 on at least 2 rims maybe all 4 and those suckers are expensive $1000+ for 4 new tires. That’s more than the rims I was looking at!
I picked those 2 sizes because they are very close to the overall diameter of the stock 215/70/15 tires.
I think the 285/40R18 tires will fit. I looked up that a 255/50R17 tire is 10.4” wide mounted on an 8” rim. So the tires have added 1.2” on each side of an 8” rim with 4.5” of backspacing.
If the 285/40R18 tire I want is 11.4” wide mounted on a 10” wide rim. It should be 11.4” or smaller mounted on a 9.5” wide rim? If correct, then a 9.5 wide rim would have about 0.95” of tire added on each side and as long as I have a 4.5” backspacing it should fit. Right?
Originally posted by 89mercury View PostA big brake upgrade is the main reason I am looking at new rims & tires. I want to convert to 2000 cobra brakes; 13" front & 11.66" rear.Builder/Owner of Badass Panther Wagons
Originally posted by mrltd View PostHave fun with that...Our brakes are offset quite a bit from a mustangs setup. Some different rotors (2 piece wilwood/brembos) in the correct offset and some custom brackets would make the caliper install possible.
