mrltd has been talking about the additional crossmembers that the police and wagons got. Im comparing my 85 sedan from to my 97 PI frame, the crossmembers should be the same being as the 97 frame is almost identical to the box frame.
this is the end of the rear frame rails on the 85.
notice that there is no frame parts connecting the two rails.
Here is the 97
the crossmember on the 97 is about 1/16" thick.
You could replicate a brace like this with some 3" C-channel steel with speed holes to reduce weight welded to each frame rail.
Here is the 97
