Don't quote me, but I think some police units had boxed upper arms. I don't know if this was a box or aero thing but I swear I remember reading this.
89 Police Sedan Rear Control Arm PIC
nice writeup!
where are you getting the illustrations with the part numbers? we need part numbers for the body mounts
Also, what other kinds of factory literature do ya have?1990 Country Squire - under restoration
Scott has a set of brandy new stock replacement lower control arm bushings (actually the uppers use the same bushings as well) sitting up there. I bought them some time ago. I have new uppers on my car, but haven't ever gotten around to installing the lower arm bushings. He's got the micrometer so I'll defer measuring to the person who isn't 100 miles away from them (me)86 Lincoln Town Car (Galactica).
My 87 allready had the PI lower control arms,but had no rear bar from the factory,nor is it a tow pack car.It has the special bent lips on the arms as well,but I still didn't have to mod anything to install it.The bar slid in from the rear and bolted right up.
Originally posted by Blaze86Vic View PostYou know, while you have them off, you should dimension out the size of all the bushings on it. Outside and inside diameter, as well as length and any other dimensions. Then we could have poly-graphite sets fabbed up.
I powder coated the two lower control arms matte black and they are ready for new bushings.
The control arms are approximately 4 lbs. each without the bushings installed.
ES makes bushings... the 92-95 are the same from what we can tell so far. You need the shells from the stock bushings though. It's easy enough to make your own though. WWW.mcmaster.com sells poly cylinders that you can machine to size.Builder/Owner of Badass Panther Wagons
Unfortunately the numbers in the service manual aren't useful at the parts counter. I dont know what those numbers actually are, but they aren't a standard Ford engineering #. I have the body mount illustration but I dont know what good the actual numbers on it are.86 Lincoln Town Car (Galactica).
