I topped it off w regular power steering that I had sitting around, I’ll grab something else. I also have the OEM air system on the car rn but I want to replace the lines along with the compressor, as I think there is a slight leak on the connection between it and the line.
89 Grand Marquis possible suspension issue
Originally posted by monotonorobo View PostI topped it off w regular power steering that I had sitting around, I’ll grab something else. I also have the OEM air system on the car rn but I want to replace the lines along with the compressor, as I think there is a slight leak on the connection between it and the line.What I Own: 1993 Mercury Grand Marquis GS
- Likes 1
Originally posted by friskyfrankie View Post
You can do a few power steering fluid changes using a turkey baster. Always remember to work the wheel all the way, in both directions, but don't hold it at the extremes for more than a second or so!
And in relation to the off topic thing I brought up, I forgot I had a spare ACT sensor sitting around so I might swap that out just to see what happens.
Yes, Type F is the first choice but I did not mention it as it may be difficult to find. The Dex/Merc III should be easier to find and work well.
If its noisy even with fresh correct juice, the Lucas power steering snot does a pretty good job of shutting them up.86 Lincoln Town Car (Galactica).
