89 Grand Marquis possible suspension issue
    I have noticed no other issues from this vehicle so far besides the popping noise from the front drivers side. It only occurs when I make a hard left onto a bump like a driveway or something. Steering doesn’t feel off or anything/ no wobbling. If someone could tell me what to check then I will check it. Thank you.
    I'd say check the sway bar end links and shocks first.
    Though your ride so far has seemed like a bit of a dumpster fire (no offense), so a nut & bolt tightness check wouldn't hurt.
    I had a bit of a soft clunk on right turns on my MGM, turned out to be a sloppy shock, the upper bushings were toast.
    2005 Volvo V70 Bi-Fuel
      No offense taken, I bought it to learn from anyways. Pretty much everything is alright with it now besides what I mentioned. I’ll Jack up the left side and check it when it stops raining.
        If you are maxing out the steering and hitting a bump, you are probably hearing the knuckle rubbing the "stopper" on the control arm. You could clean the rust off of those parts and maybe apply a dab of grease. Pic should be a close representation. Click image for larger version
          Alright thanks. I am maxing out the steering that’s the only time it occurs.
            good thought on the steering limiter. Often that makes a horrific scraping noise if its dry.
            another thing that makes random clunks is the sway bar to frame bushing, but that usually has nothing to do with turn angle. They turn to mush after a while and the bar just bangs around in the bracket.
              Back again with my lovely automobile, Seems that now I have some steering wheel play (no wheel shaking or anything, just play). When I get off tomorrow I will Jack the car up and wobble the wheels to check for worn suspension parts. If anyone has anything to add or any advice to give please do so. I will keep what you say in mind as I look for this issue. I’ll also check the steering shaft for play too, and I’ll measure exactly how much play is coming from the steering wheel then I’ll get back to this thread.
                idler arm and pitman arm are common wear items, same with the outer tie rod ends. loose wheel bearings will also make it sloppy. Check the rag joint too, if thats turning to goo the wheel turns and the box does not.
                  Yeah I was gonna check the rag joint, im going off for reference from f150s and foxbodies of around the same year. I’m guessing they mostly use the same parts and have the same issues. I changed out the bearings too about a year ago but since then I’ve hit a lot of potholes and what horribly built roads.
                    F150 yes, Fox not so much. Those are rack and pinion, no center link, idler, or pitman arm. F series has basically the same steering setup though
                    The bearings being loose usually just means it needs an adjustment. If the wheel is loose up/down tighten it one notch on the castle nut until it stops being floppy. So long as they dont run dry they really don't tend to go bad very often.
                      Alright, this problem seems to be fixed after I messed with it a bit. Next on the list is probably a power steering pump replacement, or at least bleeding the air out of it or something. I noticed the fluid was a bit low so I filled it up some. Got some whining during idle and a lil squeaky noise when I turn sometimes. Best way to describe it is that it sounds like rubber. After I get that situated, I'm replacing the rear air shocks and then eventually the front. Which brand would be close to or better than OEM?
                        Oh yeah, another thing too. Off topic, but a while ago when I mentioned my a/c would blow regular air when idling or stopped sometimes wasn’t because it was low charge, im having the same issues with heat and I already checked my coolant and burped it a few times. It probably a vacuum issue but I already triple checked everything in the engine bay so im guessing it’s probably something in the dash. I plugged off a few vac lines inside for a bit to see if any changes occurred but it remained the same. I’ll check the coffee can again one more time or I might just replace it for the hell of it since it looks pretty beat up, but it holds vacuum last time I checked. Also idle is at normal rpm’s. And if you put the car on defrost, the heat that blows out the vents remain cold, no matter if you’re moving or not.
                          Sometimes using Dex III Trany Fluid in the PS Pump works wonders. Other stuff is usually too thin but Ford pumps do tend to be somewhat noisy!
                            Power steering pump should use Type F. Dex/Merc III will work fine as well. If you use generic power steering fluid, it WILL squeal. Use ATF.
                            As for the air shocks... the MONROE MA815 Max-Air and GABRIEL 49205 Hi-Jacker are your only options really for adjustable air shocks. They're pretty much the same, so get the best deal you can find. If you don't have the air system and just mean nitrogen filled shocks (no external air lines), KYB Excel-G or Gabriel Ultra are pretty much stock cloud float feel and the KYB Gas-a-just for firmer feel (police spec).
                              Yes, Type F is the first choice but I did not mention it as it may be difficult to find. The Dex/Merc III should be easier to find and work well.
