plastic sleeve on caliper pin?
    So this is a first for me. I had to do a caliper on the Continental and the replacement came with plastic sleeves stuck into the rubber bushing that the pin slides into. I've never seen that before, but a tour through the 84 Conti, 86 Towncar, and 91 Mark VII books shows this part. Its shown here on the illustration from the master parts manual as part 2B393
    I made an attempt to use them but they do not seem to fit into the rubber bushing along with the pin so I just left it out.
    Anyone ever see these before?
    There is no such listing for any Fox or Panther platform car, only for a Festiva or a Tracer. The star next to the part number means its not supplied
    The caliper pin is the same part listed 1980-1989, I can't quite tell about the bushings, they are only part of a hardware kit.
    anyway, just curious if anyone else had run into these and if they actually fit in your caliper.
    Nope. That's a new one on me too.
      Are they there to protect the rubber bushings prior to installation?
        I'll be honest I've been fooling with these cars for a long time and I've never actually read the service manual on how to do the brakes until I ran across that sleeve. I actually thought it was something to keep the bushing from deforming in shipment when it got here. The 1984 manual says that it should be bottomed out in the rubber bushing though.
        Also I was mistaken, that sleeve is *not* in the 1991 manual so at some point along the way it was abandoned.
          Haven't seen one on my cars.
          Maybe a part that was used early on and not eliminated in a timely fashion from the service manual?
